586,656 active members*
3,695 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Endmill to cut aluminum with high speed router?
    Jan 2010
    30
    I know I've seen it somewhere, but after 10 minutes of looking I admit defeat. I read on one thread or another that there are special router bits / endmills for use on high speed (wood) routers that will cut aluminum. I want to do some simple milling using my Bosch Colt and thought I'd give it these bits a try, if I could only find them!
    Thanks much -- Paul
    standard end mills work well enough with a router
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  1. High feed endmill
    By mackie29 in forum Hard / High Speed Machining
    Last Post: 02-28-2010, 01:52 AM
  2. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
  3. Have High Speed Modem, and Dial up Using Router
    By tobyaxis in forum Computers / Desktops / Networking
    Last Post: 07-24-2006, 03:17 AM
  4. High-Speed 3 (4?) axis cnc router
    By rherman in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 04:31 AM
  5. 3 Flute High Helix Endmill Problem
    By Joe_CNC in forum MetalWork Discussion
    Last Post: 07-20-2005, 01:07 AM
