586,655 active members*
2,897 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Way to take gcode for one axis and mirror it for another axis?
    Jan 2006
    14
    I have a 4 axis machine (dual cutting heads) and I'm trying to figure out how to mirror gcode from the Z axis to also be used by the W axis in the same cnc file. Any tools/utilities out there that can take the gcode file and copy everything z does to this W axis?
    Normally I'd edit by hand but the gcode is about 12K lines per program.
    Apr 2003
    59
    I think you will need to edit your post processor to add a W axis command everytime it outputs a Z command, I'm not sure how to do that but I know it will work. I have a waterjet machine with two independent cutting heads Z and W and the post processor does this. Mark...
    If in doubt ask!
    24223
    Some machines are capable of Mirror Image, it depends on the type of machine what G code it is.
    Al.
  1. 4th gcode axis problem
    By fabconv in forum Visual Mill
    Last Post: 08-29-2009, 01:39 PM
  2. Replies: 0
    Last Post: 08-02-2009, 10:37 PM
  3. What is the gcode to ref 1 axis home after
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-07-2008, 11:18 PM
  4. Mirror image C-axis.
    By M-man in forum Daewoo/Doosan
    Last Post: 02-06-2007, 06:35 PM
  5. How to mirror GCode file?
    By anoah in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 06:26 PM
