586,388 active members*
3,188 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy Granite "s Skeleton
    Apr 2005
    252
    Manufacturing Epoxy Granite (Mineral Casting, Polymer Concrete) reinforced the need for bone?
    Suppose size is 1000 mm column milling machine, then you need to bone?
    I hoped demonstrates my cnc,laser and model
    www.modelcn.cn
    Jun 2005
    334
    It's not if you need it or not; but how you use reinforcement.
    Mounting heavy steel way beds may require reinforcement support however; it depends on the design.
    If the design requires vibration damping and reinforcement; you must make sure that the reinforcement/support does not couple any vibration source to another or the machines feet. (e.g., coupling the way beds together)
    In essence; coupling one object to another using reinforcement is effectively coupling vibration as well, while there is some damping, it's not optimal.
    Look at patent: 5,765,818 for some visual examples
    -Jack
  1. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  2. epoxy-granite in the mini lathe bed?
    By regcabdak1 in forum Mini Lathe
    Last Post: 02-26-2009, 12:18 AM
  3. "Epoxy Granite" industry discution
    By staghound_27 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-14-2009, 11:47 AM
  4. Epoxy/granite machine concept
    By Gizmot in forum Vertical Mill, Lathe Project Log
    Last Post: 02-28-2008, 09:46 PM
