I need to cut out a pocket in 40 durometer urethane rubber that is molded onto a roll. I make the aluminum roll and it gets sent out to get the urathane molded on. To save money in mold making (because there would be 35 different ones at $2000 each) we are trying to cut out a pocket on the outside diameter. Problem being, the rubber is so soft all it does is tear. I tried using a 2 flute finishing endmill and freezing the part to -6 degrees F. (in a regular household freezer) but that didn't work. To get the final outside diameter the rubber company grinds it to size. I was thinking on trying a small grinding stone from like a dremmel tool. I also was thinking on freezing the part in dry ice or liquid nitrogen?
Has anyone had any experiances with cutting or ginding such a material?
Ideas?
Tool type?
Endmill (diameter, helix, coating)
Grinding wheel (type, coarse, fine)
Surface speed?
Feed?
Depth of cut? (I'm guessing really small as to not apply too much cutting pressure)
