587,012 active members*
3,458 visitors online*
    Nov 2006
    24
    Exclamation Bridgeport Torq Cut 22 HELP PLEASE!!
    We currently ran into hard drive issues with our Torq Cut 22, DX-32 controller.
    I changed the hard drive, reinstalled DOS 6.22 and the operating software to version: 4.30/6.81.
    Machine boots up but when I try to turn the drivers on I get the following errror: "C-axis drive over current fault".
    I tried contacted Hardinge but they can't help me nor can the company we purchased it from 14 years ago.
    Any help would be great, also if anyone has updated software I can get that would be great also.
    Thanks!
    Nov 2004
    3028
    Do you have a 4th axis on the machine?
    Usually when the 4th axis is plugged in, a set of pins are used as a jumper to tell the control. Then the C axis is displayed on the CRT and it expects it to be homed.
    George
    Nov 2006
    24
    Thanks for the reply.
    No there is no C plugged in.
    From what I gathered its my back up settings that have not been installed.
    Any ideas?
  1. Bridgeport Torq-Cut TC 3G??
    By Kristjan in forum Bridgeport / Hardinge Mills
    Last Post: 11-02-2017, 11:47 AM
  2. Bridgeport Torq Cut 30
    By charliemisa in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2010, 12:11 PM
  3. Bridgeport CNC Torq-Cut 22, need advise
    By Barney in forum Uncategorised MetalWorking Machines
    Last Post: 04-08-2009, 12:42 AM
  4. Bridgeport torq cut-22 problems!!
    By baystard in forum Bridgeport / Hardinge Mills
    Last Post: 01-17-2008, 08:22 PM
  5. Bridgeport Torq-Cut 2G-?????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 10-21-2006, 06:56 AM
