586,453 active members*
3,006 visitors online*
    May 2009
    11
    Need G-code generator
    I am looking for G-code to control a stepper motor CNC router (6090 style). I have the CAD drawings (.dxf format) .... I need to vector mill slots in a polypropylene sheet stock as per the dxf file. The slots have tapered walls and are 12 mm deep. Does anyone know of a lower cost software program that could be used to develop the G-code?
    Does anyone have a service that could generate the G-code file? I appreciate all comments ...... thanks!
    Apr 2010
    14
    You can use deskcnc or deskam from www.deskcnc.com
    www.deskam.com
    Joe
    Apr 2010
    14
    Deskam is very simple to use and performant for router or 2 1/2 mill
    I think you can use the trial version for 15 days or something
    Joe
    May 2009
    11
    Thanks for the G-code tip
    Hi Joe,
    Thanks for the G-code tip ..... I'll check out DeskCam ASAP.
  1. EMC with what g-code generator?
    By randyf1965 in forum LinuxCNC (formerly EMC2)
    Last Post: 09-18-2011, 04:00 PM
  2. toolpath generator for g-code
    By cris_on_web in forum PCB milling
    Last Post: 09-03-2008, 12:29 PM
  3. NC Code Generator
    By vijaychd in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-26-2007, 07:39 PM
  4. CNC Code Generator for end milling
    Last Post: 05-18-2006, 07:17 PM
