586,704 active members*
2,495 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Tuning new servo drive to match others
Results 1 to 2 of 2
    Mar 2005
    11
    Does any one have a procedure to tune in a replacement Yaskawa servo drive for a BMC 20 to match the speed of the other 2 older drives? I recently replaced a drive and when I cut a circle I get more of an egg shape.
    Jun 2008
    1104
    Check the jumpers are set the same as the X or Y depending on which amp you have changed. Roughly set the pots to the same settings (VR1, VR4 & Zero. Avoid moving pots that have been paint-marked.
    Jog the axis (or write a program) to be set up at 1016mm/min (40 IPM).
    Connect a voltmeter with the positive lead on TM3 pin 2 on the servopack and the negative lead on the 0v terminal.
    Adjust VR1 (coarse adjust)first and VR4 (fine adjust) after to get 0.95v DC both ways (use the Zero pot to make the forward reading match the reverse).
    Check the other amps to ensure they are set correctly too.
  1. adding 4th axis: need to match existing servo?
    By BiggerHammer in forum CNC Machine Related Electronics
    Last Post: 01-14-2010, 01:35 AM
  2. How do I choose a servo to match my current setup?
    By BiggerHammer in forum Servo Motors / Drives
    Last Post: 01-12-2010, 05:01 PM
  3. Question aboout motor/drive match
    By Thomasdj in forum Servo Motors / Drives
    Last Post: 10-05-2009, 10:46 AM
  4. Tuning a G340 servo drive
    By chas in forum Gecko Drives
    Last Post: 04-07-2005, 01:15 PM
  5. Anyone with experience tuning a Compax servo drive?
    By ESjaavik in forum Servo Motors / Drives
    Last Post: 08-14-2004, 12:33 AM
