586,713 active members*
2,950 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > can someone double-check? (powersupply)
    Apr 2005
    55
    greets all.
    new & having a blast. just got my Gecko 210's and it seems
    like my breakout board is taking forever to get here.
    they'll be driving two steppers (6amp, .35ohm, ~500ozin) for a plasma cutter.
    i've built an unregulated powersupply with a mystery transfomer. its heavy and i'm hoping it'll do the trick. on the business end its putting out 60V (no load).
    by my math: V=IR so my motors are 6*0.35 = 2.1 V
    my gecko tech sheet says no more than 25x motor rating so thats
    52.5V.
    is 60V safe or should i pull it down 7.5V with a few diodes/LEDs?
    i have two terminals on the powersupply (for star wiring) that are both fused (6amp fast-blow) ... should this be ok or is there a spike when these things start that'll blow the 6amp?
    any help greatly appreciated,
    -anthony
    Aug 2004
    2849
    you should be okay....you won't drop the voltage with LEDs...not at the current required.....in line diodes you'd need 10 and they would have to be 6 to 10 amps....and you'd have to add some resistors across them to handle the back emf......
  1. Double Checking!!
    By chas in forum Gecko Drives
    Last Post: 04-12-2005, 05:38 AM
  2. PowerSupply Voltage problem
    By grabben67 in forum CNC Machine Related Electronics
    Last Post: 01-26-2005, 01:56 PM
  3. No Pulse?
    By jubee in forum Computers / Desktops / Networking
    Last Post: 07-08-2004, 10:11 AM
  4. check this guys invention out... will save a lot of energy world wide
    By WallCrawler in forum Community Club House
    Last Post: 06-09-2004, 09:35 PM
  5. How To Check Champer
    By ryanduc in forum Uncategorised CAM Discussion
    Last Post: 02-11-2004, 07:15 AM
