586,481 active members*
2,243 visitors online*
    Nov 2003
    314
    line numbering
    Do the line numbers i.e. N100 need to be in order ?
    Sometimes I need to move about the code, and have been renumbering them to keep them in order.
    I have tried it with my cnc simulator and it seems to work ok if the numbers are not in order but I hav'nt tried in on my machine yet.
    I am using turbocnc4
    Jun 2004
    450
    Nope, numbers are pretty much for reference only (as far as I know).
    Some controls can actually have decimal format line numbers.
    N10.2
    N10.4
    Dustin B.
    I hear and I forget.
    I see and I remember.
    I do and I understand.
    Nov 2003
    634
    Yes, you don't even need the line numbers. They are only used for manual editing. It makes finding a troublesome spot of code easier.
    This free program contains a line renumber feature if you want to use it.
    http://www.betatechnical.com/autonc.htm
    24223
    Quote Originally Posted by buscht
    Unless you use Goto instructions
    Al.
    Apr 2004
    18
    On a very limited numbers of controls the line numbers must be present, in sequence and not be repeated, Fadals come to mind.
    Experience is what you get when you don't get what you want.
  1. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  2. How to do 2 "IF" statements on the same line?
    By murphy625 in forum CamSoft Products
    Last Post: 04-02-2005, 02:28 AM
  3. Single Line Font?
    By squarewave in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 01:03 AM
  4. Single Line Fonts
    By A. Shuford in forum Uncategorised CAM Discussion
    Last Post: 11-14-2004, 03:21 PM
  5. Tool tables
    By Nimrod in forum Mastercam
    Last Post: 11-24-2003, 09:31 PM
