Originally Posted by
spaltiel
I almost done building my 1st machine however I'm having difficulties with the pins of the parallel cable. I'm using "Keling KL4030 with C10 breakout board kit". I would like to wire my parallel cable from the CNC driver to the computer but I'm not sure about the diagram. I have lots of parallel cabels but I'm almost sure that standard printer cable is not wired correctly to operate the CNC driver. Does it standard wiring from pin 'x' to pin 'x' or something else?
You need a 25 pin male pin D-sub connector on each end (unless your CNC driver needs a 25 pin female connector) and the wiring is pin 1 to pin 1 through pin 25 to pin 25. A "straight wired" cable.
CarveOne
CarveOne
