586,655 active members*
3,973 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > DOWFROST Heat Transfer Fluid
Results 1 to 7 of 7
    Apr 2008
    87
    Post DOWFROST Heat Transfer Fluid
    I know there are some old threads on this, but after some digging around I found a few distributors and figured I would post the info for anyone looking for the stuff.
    Dow distributes directly to Hubbard Hall their phone number is 203-756-5521 They have distributers across the country. There are two in the Southern California area.
    1.) Loyalty 949-654-9510 (Los Angeles)
    2.) Golden West Lubricants 626-442-3009 (South El Monty and Pomona)
    Golden West was a bit cheaper @ $147.00 for 5 Gal.
    There are two other companies Dow directly distributes to that I did not call, they are:
    1.) Ashland 800-531-7106
    2.) Brenntag 800-852-0372
    :cheers:
    Feb 2005
    376
    FadalCNC.com $55 for 2.5 gallons, even cheaper.
    Sep 2007
    27
    Dowfrost
    The stuff from FadalCNC.com, is it the same? Seems cheap.
    Apr 2005
    1194
    FadalCNC.com stuff is most likely a mix with water. So you can probly buy it 100% concentrate or mixed. If your going to do it then do it right and buy it mixed so you can guarantee its not mixed with contaminated water. IIRC
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Sep 2009
    33
    The factory offers the same stuff called CCA-HT for $23.00 per gallon. Fadal engineers have determined this is chemically the same as DowFrost. Call 818-727-2100
    Pat Grantz
    Director of Operations - PowerInterface iMPACTiq
    Apr 2012
    5
    50/50 with dionized water is best
    Sep 2012
    go to home depot
    Go to home depot, they have rv antifreeze with dowforst in it. that is all you need. about $3.00 a gallon. the dowfrost is just a comercial food grade rust and corroison inhibitor.
  1. Replies: 2
    Last Post: 04-22-2009, 08:10 PM
  2. Heat Transfer Prop. of Pratley "Steel Quickset"
    By Bryan GD in forum Material Machining Solutions
    Last Post: 04-07-2009, 01:32 PM
  3. to heat or not to heat - that is the question?
    By stirling in forum Stepper Motors / Drives
    Last Post: 09-04-2007, 09:44 AM
  4. Dowfrost
    By mad mark in forum Fadal
    Last Post: 01-30-2007, 04:07 PM
  5. Antifreeze instead of Dowfrost
    By Jedi in forum Fadal
    Last Post: 11-09-2006, 08:43 PM
