586,401 active members*
2,747 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Panasonic dv-700 inverter
Results 1 to 15 of 15
    Apr 2004
    47
    I've done a lot of searching on this website and others for a users manual for the panasonic dv-700 inverter, and I've come up empty handed. I've got it hooked up and running my bridgeport cnc mill spindle, but unless i start the motor with around 30 hz or less, the drive gives an overcurent fault and shuts down. If I start the spindle at 30hz and ramp it up it to 60hz everything seems fine. No buzzing, no problems what so ever. The inverter came from a surplus store, and as such has absolutely no documentation. Does anyone out there have a manual for this drive. Or at least have used one before and can explain how to set the accell rates, or other variables on it? Any help would be greatly appreciated.
    Edit: The inverter is driving a 1980's bridgeport j-head with 1.5 hp spindle motor. Thanks
    Jan 2009
    237
    jrc
    I have no particular knowledge of your Pannasonic VFD, but, by the performance, it sounds like the unit is undersized (Too few AMPS) for your motor application.
    Faulting on start up is a sure sign. Though it could be the Accel rate. If the motor is unbelted, or at lease on a very light inertia load, how long does it take the spindle to come up to speed?
    You need a VFD rated for your motor amp draw, and your input Voltage and Phase (1ph or 3ph)
    Often, there will be strong similarities across different models from the same maker. Down load the information on the VF-C series drives from Pannasonic, and see if there are any clues for your set up.
    Try again! http://www.toodoc.com/manual-inverte...sonic-pdf.html
    Cal
    24223
    I believe it is a Matsu****a VFD, you could try these guys and see if they will supply the full manual.
    http://www.ctiautomation.net/PDF/Pan...-Inverters.pdf
    Al.
    Apr 2004
    47
    Thanks for the info guys, I wil try to get in touch with panasonic or the original manufacturer, since this drive seems to be outdated and not supported anymore. The particular drive I have is rated for 7A according to the sticker on the unit, my motor is rated at around 5A peak, so I'm fairly confident about the accell rate being wrong. Other than that, the drive seems to work fine with no issues once the motor is turning. I took some pretty heavy (~ .125")cuts in aluminum today with a 3" indexible face mill with no hint of overload, and the motor ran for about 40 mins with no problems. One more question if i may, Are VFDs usually programmed through a download from a pc, or right at the controls? Thanks again for the help.
    Jun 2010
    Arrow
    need "Panasonic inverter DV-700" connecting diagram, how can check or testing it, and how can repair it.
    Pleas Help Me............
    Jun 2010
    Arrow Bar-taking machine LK-1900A
    Need "Bar-taking machine LK-1900A" Electronics diagrams of Motherboard & Power supply. And how can i repair it.
    1. Program IC --- OK
    2. Ram IC--------OK
    3. Power supply--OK
    4. Motherboard have no Power & Nothing to Display.
    5. Motherboard have throw for check another Machine, But no Power & Nothing to Display.
    How cane i check hols-machine And How can i repair sir, (Need Electronics diagrams)
    Please Help Me Sir, Any-Body. pls..............
    24223
    Virtually impossible to get schematics for this type of machine, they are proprietary.
    If there is no power at all on the board then it sounds relatively easy? Power supply/regulator components?
    Al.
    Dec 2006
    325
    When Juki first came out with the LK-1900 series programmable tackers, they were using Pana Minas servo motors.
    Have you tried to get the information from Juki Bangladesh in Dhaka? They can help you in troubleshooting the problem.
    Best regards
    Bruno
    Aug 2008
    7
    I to am looking for a users manual for a dv-700 inverter I have removed it from an old control panel it looks like it works OK but is fixed at 45 hz I need to know how to set it up for my mill motor
    yours Paul
    Aug 2008
    7
    My randomly playing I have found thai if you apply the power whilst holding down the mode button it unlocked the set frequancy and allows adjustment with the up / down buttons bwtween 25HZ and 60Hz
    still trying to get a manual can any one help?
    Paul
    Feb 2011
    dv 707 manual probably here
    Hello Ppl. I also have an Panasonic DV707 from a printing machine, and I try to find the parameters.
    On this website it looks that they have something but google couldn;t translate it.
    Maybe you can find it there.
    ±??DV707H
    Mar 2011
    Wink
    Download this PDF , text it's Chinese ,I can read and Understand it ,you do?try it,^_^ luck....
    http://download.gongkong.com/file/2005/11/17/DV700.rar
    Feb 2011
    thank you
    Quote Originally Posted by Fmole View Post
    Thank You!
    It looks that the time when I should start learn chinese it is closer than I thought.
    Sep 2014
    Re: Panasonic dv-700 inverter
    Try this file
    DV700Tseries_manual_e
    Feb 2011
    Hello! Thank You ! Looks great. I didn't know this manual had actually existed in English. Thank You very myuch. I still have the inverter somewhere. I will try to start it.
  1. Panasonic MDD103A1VE
    By dango in forum CNC Machine Related Electronics
    Last Post: 08-09-2013, 08:39 AM
  2. Datasheet for Panasonic Frequency Inverter DV-707 and M1D042W1X
    By Syphonics in forum CNC Machine Related Electronics
    Last Post: 05-09-2011, 04:04 PM
  3. panasonic servos
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 01-13-2011, 11:30 PM
  4. I need datashhet for Panasonic MSD***
    By Nikomas in forum CNC Machine Related Electronics
    Last Post: 01-07-2011, 09:45 PM
  5. panasonic motion second
    By LaserToolShop in forum Servo Motors / Drives
    Last Post: 08-21-2007, 09:32 PM
