586,354 active members*
3,358 visitors online*
    Jan 2007
    36
    Can't reach DynaCNC and need info
    I have a 24" x 36" table and I want to upgrade it. I has some backlash on one side of the long axis and I want to replace the lead nut but I don't know what the rod dimensions are. I'm away from my machine right now and would like to buy the components and have them waiting when I return.
    Also, the Z axis is way too close to the table (Bad design). I'd like to buy some of the same extrusions they use for the base and just raise the axis by using that as sort of a shim. Anyone know where to get some of the extrusion?
    Dec 2005
    43
    dynacnc
    Dyna cnc has gone under for some time. You can measure the lead screw and order parts from another company,
    The good thing about dyna they used no propriety equip. so you can get parts anywhere.
    The extrusions are 80/20 they can be bought from the company or bought on ebay.
    Jan 2007
    36
    I saw the extrusions on EBay but didn't find the right one. I'll have to look again.
  1. End mill reach !?
    By zaebis in forum MetalWork Discussion
    Last Post: 08-06-2009, 09:24 PM
  2. long reach 82 degree countersink
    By kendo in forum MetalWork Discussion
    Last Post: 04-08-2009, 05:51 PM
  3. What time does it take to a stepper to reach 600 rpm ?
    By cnc2 in forum Stepper Motors / Drives
    Last Post: 01-12-2009, 05:59 AM
  4. Long reach milling bits
    By xcayba in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-01-2008, 05:50 AM
