586,384 active members*
3,658 visitors online*
    Apr 2010
    Problem with fanuc 01
    I have the following problem with FANUC Series Oi Mate model B
    When the machine is switched on the following alarm appears:
    971 NMI OCCURRED IN PMCLSI
    With the PMC-SA1, an error occured in the PMC control LSI device on motherboard
    (I/O RAM parity)
    We can't do nothing then.
    Any suggestions for dissolving this problem?
    Jun 2008
    1511
    I have never personally had this error but found the alarm message and description in the manual. It says to check the I/O unit. See attachment.
    Stevo
    Attached Files Attached Files
    Feb 2007
    38
    971 usually means the main pcb has to be changed. Good new is you can still go to the boot screen and back up the SRAM. Bad news FANUC will not sell a main pcb without service coming out to replace it.
  1. Fanuc 18M oil problem
    By mustafaguler in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2008, 08:35 AM
  2. Fanuc 21i-T DNC Problem
    By Stebedeff in forum Fanuc
    Last Post: 07-16-2007, 09:00 PM
  3. Fanuc 6M Problem
    By Mimas in forum Fanuc
    Last Post: 12-17-2006, 01:03 AM
  4. Fanuc 0M problem
    By bauhar in forum Fanuc
    Last Post: 09-12-2006, 04:01 AM
  5. Fanuc 6mb G54 problem...
    By kangarabbit in forum Fanuc
    Last Post: 05-08-2006, 08:35 PM
