586,785 active members*
2,913 visitors online*
    Feb 2007
    32
    Best Gantry Material
    Hi All,
    What is the best material to use for a machine gantry?
    Aluminium or Steel? I have been speaking with my local machine shop and they said that aluminium expands a lot with heat. How hot would the gantry of a machine get when cutting thick material with oxy fuel for example. I am thinking that aluminium would be far lighter and keep the inertia down.. The machinist has 40 years experience and was slightly put off by the thoughts of using 80/20 type extrusion for the gantry..
    Ron
    Aug 2007
    264
    How big is your machine? Size could be a factor.
    We have a 4' x 8' plasma witha 3" x 3" alum. gantry, works great. I cut quite a bit of 1/4-1/2 plate, never had any issues with gantry.
    Mike
    Feb 2007
    32
    Im currently just in the design process (for the last 2 years)...The table will be 10 x 5....
    Mar 2009
    924
    Quote Originally Posted by rgillard View Post
    Hi All,
    Ron
    Ron, Most of the heat would be zone/reflective. You can contain that heat with shields. Aluminum is pretty stable but steel is somewhat less expensive. I have a steel gantry but aluminum would have been OK.
    Here is a link to a really nice aluminum gantry build. If I was to build my own I would consider this route:
    http://www.cnczone.com/forums/showth...105#post759105
    WSS
    1260
    I have a steel box tube gantry. It absorbs quite a bit of heat when cutting 1" material in a chain cut program. (lots of small parts in a tight area of plate) It never gets hot enough to make Aluminum become unstable. It doesn't get to hot to touch but does get to hot to hold on to. I don't think it is so much direct heat from the torch flame as it's heat radiating off the 1" steel that's being cut.
    I agree with WSS Aluminum should be fine for a gantry. If you are using small motors & drivers Al will almost be a necessity.
    If it works.....Don't fix it!
  1. Gantry: planning to design moving open gantry
    By rdcd in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2009, 10:52 PM
  2. Replies: 2
    Last Post: 09-15-2009, 05:09 AM
  3. Gantry
    By alexis221 in forum DIY CNC Router Table Machines
    Last Post: 11-10-2007, 04:17 PM
  4. gantry
    By posix in forum Linear and Rotary Motion
    Last Post: 01-14-2006, 11:57 AM
  5. Alternative material for gantry parts
    By owhite in forum DIY CNC Router Table Machines
    Last Post: 02-10-2004, 07:26 AM
