587,013 active members*
3,803 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > Mach 3 Spindle Speed Table Feed Calibration/Synchronization
    Apr 2005
    1268
    Damn, I hope I spelled that right!
    I have a benchtop mill running mach 3 with a Hitachi 200 VFD, 3 phase motor (2hp) and a cnc4pc speed control card. I'm using 0 - 10 volts to the VFD and have a tach circuit installed on the spindle which is being reported to Mach 3.
    Is there a way to set up the software to allow mach to monitor the spindle speed and slow down feed if it starts to bog down????? My equipment configuration tends to break a bunch of mill tools due to the motor bogging down during a cut. Very frustrating and expensive.
    Thoughts anyone?????
    Bill
    :wave::cheers:
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    You may be able to use the macropump (which runs a macro 10 times a second, I think) to read the rpmand adjust the FRO when the rpm drops. Not positive, though. But you'll need to write a macro to do it.
    Apr 2005
    1268
    Thanks Gerry!
    Sounds like a fun project. I'll have to put it on the list though! Too many irons in the fire at the moment!
    Bill
    billyjack
  1. Spindle speed calibration
    By Fastest1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-12-2009, 05:25 PM
  2. About feed rate and spindle speed
    By yanlo in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2009, 12:34 PM
  3. spindle speed/feed rate
    By lamed in forum MetalWork Discussion
    Last Post: 06-03-2009, 12:25 PM
  4. CNC feed rate and spindle speed
    By misc.garfield in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-30-2008, 12:20 AM
  5. Syil X3 Mill Spindle Speed Calibration Procedure
    By Chrisjh in forum Syil Products
    Last Post: 01-12-2008, 08:54 AM
