586,796 active members*
2,609 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > couldn't activate the debugger
    Dec 2006
    29
    I activate the debugger on MCAM3 utility but I can't get the icon for debugging on the post manager. can any one help me with this please?
    Jun 2009
    99
    I have had the same problem on X4 can anyone help on this?
    Mar 2005
    988
    By "Utility"... you went through the START menu function right? The old switch doesn't work in X3 and X4.
    Go to your Windoze Start menu then Programs > Mastercam X(your version) > MCAMX Control Panel Applet. Once there, expand the dialog and select "Post support". Select "enable" and close the window using the check mark.
    Open your MCX and when you post, you'll see a little "bug" in the bottom left corner of the pop up. Select the 'bug'.....
    X4 is very enhanced so you may want to read over the Help files to get around.
    It's just a part..... cutter still goes round and round....
    Jun 2009
    99
    got the bugger to work in X4 just neeed to sit down and learn how to use it.
  1. How do I activate the HPCC???
    By jsmith2232 in forum Mori Seiki Mills
    Last Post: 02-24-2011, 04:39 PM
  2. Post Debugger
    By littlebrewman in forum Mastercam
    Last Post: 02-24-2010, 03:33 AM
  3. Using VB as a G-Code debugger / editor
    By BonusODJ in forum Visual Basic
    Last Post: 12-22-2008, 08:49 AM
  4. Hotkey to activate plugin?
    By bigz1 in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-24-2008, 07:19 PM
  5. How to activate part timer on 10t?
    By Crashmaster in forum Fanuc
    Last Post: 09-21-2007, 01:05 AM
