586,495 active members*
1,698 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Bobcad as a post-processor?
Results 1 to 8 of 8
    Jul 2009
    71
    I was wondering if there is any way to use bobcad to translate NC code? I don't have a mastercam post for my new machine, but I do have one for bobcad... I was wondering if anyone knows if a guy can take in FANUC or some other standard NC from mastercam or something, and then convert it with a working post in bobcad(V21)?
    Thanks a million for any help anyone might have!
    -Parker
    Jun 2003
    205
    G Code Conversion
    If you are looking to convert G code programs from one format to another ... I don't think you can do that through a CAD/CAM package ... you would have to re-create the drawing / toolpath.
    You might take a look at KipwareXC ( www.kentechinc.com ).
    Jul 2009
    71
    so, the post for bobcad only works when it converts toolpaths in the drawings to nc code? I didn't know if that was the case, or if it also could go through a conventionally written nc file, and change it per a specific dialect.
    Jun 2008
    1838
    Quote Originally Posted by parkerbender View Post
    -Parker
    If you can produce the correct code for your new machine in BobCAD then you must know what the NC Code needs to look like, if so can you not Edit a Mastercam Post Processor that is fairly close to your machine to output the correct NC Code ??
    There is some info here on Editing Mastercam Post Processors
    http://www.mmattera.com/mastercam/po...te_a_post.html
    Or here
    http://www.emastercam.com/
    Regards
    Rob
    :rainfro::rainfro:
    Jul 2009
    71
    I'm assuming that that is what I'm going to end up doing, I was mainly hoping for a workaround for the time being, to get the machine running quicker, while I learn how to work on posts (I'm inside one currently, and am pretty intimidated...) plus the hurco does a strange thing that it's z values are positive on both sides of the retract plane, and it goes into incremental when in canned cycles, which I don't really know how to change that stuff...
    Thanks for the links, and if anyone has any other insight, that would be awesome!
    Thanks!
    -Parker
    Dec 2008
    4548
    Load up your part in BobCad and toolpath it and post the code. While you learn Mastercam.
    Jun 2008
    1838
    Thanks!
    -Parker
    What Hurco do you have ?? I have 2 of them and never had a problem with either of them programming anything, having said that mine do both have the Ultimax III twin screen controls with the full conversational software, Ultipocket, 3D Mould, DXF input etc so I`m not in the unhappy position of having to produce NC Code for them!!
    However, if you have the top of part set at Z zero then any move above that will be a positive value so regardless of where the "detent" ( Retract plane) is the values will certainly be positive either side as they are both above the Z zero.
    Burrman is right, can you not just do what you need in BobCAD if it is producing the code for you then you can take as long as you like getting the Mastercam stuff sorted ???
    Jul 2009
    71
    The part i'm doing is vaugely complex, and I'm looking for a surface that I can send almost directly out to be e-nickel carbide coated. Bobcad might do it, I had felt in my early experience with it, that it's capabilities at surface finishing are limited. I might have to further inspect it's potential...
  1. BobCAD-CAM v23 Mach3 Post Processor
    By ShineMachineCo. in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-01-2009, 04:42 AM
  2. Tormach / Bobcad v21 post processor?????
    By highspeedmazak in forum Tormach Personal CNC Mill
    Last Post: 07-27-2008, 09:44 PM
  3. post processor for HAAS vf2 (bobcad)
    By joesimmers in forum Haas Mills
    Last Post: 12-13-2007, 08:46 PM
  4. BobCad-Cam v19 post processor installation
    By goodeye in forum BobCad-Cam
    Last Post: 11-24-2007, 03:33 AM
  5. BobCAD-CAM v17 post processor help
    By johnmac in forum BobCad-Cam
    Last Post: 10-10-2007, 09:29 PM
