OK
OK
Hi David.
May I know the setting?
I have been reading this thread but it really beyond my understanding. I just need basic setting for this board in Mach 3.
Thank you.
http://www.cnczone.com/forums/genera...chinese-2.html
Each board that contains a TB6560 is different, for example:
For the red board found here Red TB6560 driver board
the pins used are "For X axis P2, P3" "Y Axis P4, P5", "Z axis P6, P7"
Now the Blue board with the same IC has the following pinout "X axis P1, P2, P4, Y axis P5, P9, P12, and Z axis P7, P8, P10 tb6560 driver board on a Rep-Rap machine
If you send me a link to the board you'r using I can get you a configuration file.
Cheers,
Rob
what is a cnc
