This is what I am finding out. I am just about finished with tear down and cleaning, but my gibs and some of the dovetail surfaces don't look so good.
I spent most today polishing the z-axis gib. It looked warped and was only polishing up on the ends. Some of the ways had been painted. The surface finish on important areas wouldn't pass muster for non-critical areas where I have worked.
After all my work I reassembled the z-axis and the movement was noticeably improved.
I still don't think I did that good of job on the dovetails, now that my gibs are parallel and mirror finish I may try lapping the dovetails.
I'm beginning to realize what you're really buying is all the raw materials to make a mill. It's up to you to actually make it one.
BW, thanks for that link, I may go ahead and do that for dampening, since I already have epoxy on hand. While I am at it I might do the base as well.
I am aware of the potential allergic reactions. I know some people that had to give up boat building because of the reaction. You don't ever want the stuff wet or dry touching your skin (and if you're sanding it, you need a mask and good dust collection). After my initial fears I became an epoxy nut. It is the solution to *everything* .
TroyO, plan on doubling your estimates for time spent getting the machine ready. I'm pretty sure I won't be cutting chips for another two or three weeks. Of course I tend to go OCD on tool accuracy, I even have a DRO on my table saw.
Tearing it down completely has been a good exercise. Every step shows me another potential area for adjustment.
