586,129 active members*
3,153 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Create pdf from bcc V23
    Oct 2008
    27
    Hi I was looking for a way to create pdf out of bcc V23 drawings to email what is the best soft ware to use if it can be done.
    Jun 2003
    205
    PDF Creation
    One of the best tools we recommend is the FREE CutePDF program from www.cutepdf.com
    It basically installs itself as an additional "printer" ... in any program, Word, Excel or your CAD program ... you proceed as if you were going to print your document or drawing to a regular printer ... select CutePDF as the "printer" ... and anything that would have gone to the printer gets created as a PDF file to your selected filename and location.
    It's free, installs easily and is easy to use. One of the best features is if it looks good on your printer, it will look the same in the PDF file.
    Hope this helps ...
    Real World Machine Shop Software at www.KentechInc.com
    Oct 2008
    27
    Thanks blue chip ill try this.
    Jun 2008
    1838
    Here is the link for the one I use, again a free download and is also very good, just select as a printer and save out the PDF.
    Very quick and easy.
    http://sourceforge.net/projects/pdfcreator/
    Regards
    Rob
    :rainfro::rainfro:
  1. Create Arc
    By jcnewbie in forum Mastercam
    Last Post: 01-07-2010, 04:28 AM
  2. create 2d toolpath
    By daisydog in forum MadCAM
    Last Post: 02-20-2008, 07:15 PM
  3. create 3d dxf drawing
    By brockadeau in forum BobCad-Cam
    Last Post: 01-31-2008, 03:23 PM
  4. How do you create this toolpath?
    By squarewave in forum Mastercam
    Last Post: 10-18-2006, 01:40 AM
