586,955 active members*
2,899 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Spindle bearings on a Warco Wm-16 mill
    Oct 2008
    31
    Hi All
    I have recently noticed a noise coming from the spindle on me WM-16 warco mill and was wondering if anyone has changed their bearings, if so could you advise me on how to strip it down.
    Hope someone can help.
    Ian
    Jun 2007
    3891
    Quote Originally Posted by boxmaker View Post
    Hi All
    Ian
    i believe the wm16 is the same model as the grizzly 0704. theres is a thread by hoss where hes pulled the bearings out. he should be able to give you advice here.
    Oct 2008
    31
    many thanks
    Ian
  1. warco mini mill X and Y not 90 degrees
    By MICHAELT in forum Benchtop Machines
    Last Post: 12-10-2010, 02:10 PM
  2. Taig mill/lathe spindle bearings
    By japroach in forum Taig Mills / Lathes
    Last Post: 09-08-2010, 02:14 PM
  3. Ex-cello Manual Mill- spindle bearings?
    By Miller Man in forum Bridgeport / Hardinge Mills
    Last Post: 07-03-2009, 09:43 PM
  4. replacing CNC mill spindle bearings
    By OC_ in forum MetalWork Discussion
    Last Post: 03-23-2007, 10:29 PM
  5. Mill Drill Spindle Bearings
    By Dirt Rider 3006 in forum Benchtop Machines
    Last Post: 12-20-2006, 01:52 AM
