Originally Posted by
Kool Parts
..... I will be using it for 99% shaft work very small cuts...... cant justify 150,000 for this work.
Gary
Have you considered the TL2? This will give you the Z length and it can handle small cuts very well. If you are only doing shaft work it is likely you could use the base model TL which comes in well under 150k even with the faster spindle speed. The rapids are slow out of the factory but you can change them.
