586,488 active members*
2,895 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Fanuc servo and spindle control with mach3
    Feb 2009
    17
    Question Fanuc servo and spindle control with mach3
    Hello every one,
    Is there any guy around who used fanuc servo with mach3
    I am very newer to fanuc systems. i had never used it before or converted!
    there are surplus servo drives and spindle control from scratch machine.
    the fanuc CNC control is old and i am going to replace to accept mach3's raw pulse and direction.
    for Fanuc servos and spindle system model nos. found from the cabinet
    1) A06B-6079-H203, 2.5Kw
    2) A06B-6081-h106, 9.4Kw
    3) a06b-6082-H211#512, 13.2Kw
    :cheers:
    Mar 2009
    106
    To get full benefit of those servos I would suggest EMC2 rather than Mach as you will able to create a true closed loop system. Pico systems has reasonably priced boards that can tie everything together. http://pico-systems.com/oscrc4/catal...ex.php?cPath=4
    Feb 2009
    17
    Question Any one help me for configuration with mach3!!!
    marzetti Thanks for your reply,
    But i am in confusion for perticular that model of drives! i tried googling but not found any satisfactory detailed info!!!
    i needed help on finding connection diagram, parameter settings, tuning etc, etc... like adapting newer servo/VFD to controller soft. like mach 3 or any other. there is no issue on reliability for mach3. i don't know about Linux CNC. but have interest to try out EMC!!!
    :Cheers:
    :Cheers:
  1. mach3 spindle control on nm-200
    By urbanimports02 in forum Novakon
    Last Post: 01-19-2010, 04:33 PM
  2. Setting up Spindle Control in mach3
    By UKRobotics in forum Mach Mill
    Last Post: 10-18-2009, 10:34 PM
  3. Mach3 spindle control of Boxford 260 VMC
    By jwhitley in forum Benchtop Machines
    Last Post: 09-09-2008, 06:21 PM
  4. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
  5. SX3 spindle speed control with Mach3
    By bbox in forum Benchtop Machines
    Last Post: 07-05-2008, 11:15 PM
