586,395 active members*
2,716 visitors online*
Thread: Zeros reset
    Apr 2009
    4
    Zeros reset
    I'm not sure that this is a software issue (running Mach 3) but I have my suspicions the problem is at the computer end and not the router end...the zeros of first just X and Y and as of Friday Z too, have been reset to another position without any changes made at the user end. This reset has occurred in the middle of cutting and while the machine was off or not running. And we're not talking a few inches here, it's usually 11in+, .5in on the Z axis. Read another thread about glitchy behavior solved by a windows update, I will try that. Does this sound familiar to anyone? Any other suggestions? Thanks!
    Aug 2009
    136
    hay i have a problem do you know how to set the mechine coord's Zero i can not get it to set to zero every thing is good but the mechine zero can not get it to zero ( i'm trying to set up my table) if you can help thank you
    kevin
  1. Reset button = Hot key
    By zaebis in forum Mach Software (ArtSoft software)
    Last Post: 08-05-2009, 02:08 AM
  2. Manual Setting of Work Zeros (0-M fanuc)
    By venomgrrrl in forum Fanuc
    Last Post: 07-08-2009, 06:43 AM
  3. Why does my program reset
    By MetalMolder in forum Fadal
    Last Post: 04-20-2008, 09:32 PM
  4. reset zero
    By jrick in forum Commercial CNC Wood Routers
    Last Post: 01-13-2007, 11:54 PM
  5. VMC-966 (reset) )=
    By novydcute in forum Uncategorised MetalWorking Machines
    Last Post: 10-18-2006, 08:09 AM
