I'm not sure where to even begin. I've been banging my head off of this problem for a week now.
I am making a jig out of 60" x 120" MDF (don't laugh - our tolerances are +/- 1/16 of an inch, give or take), just simple pockets used to drill holes in crimped window frames for mounting holes. The pockets are simple, done, woohoo.
The problem is - I need to scribe some text on each pocket, to show orientation of the frame, as well as the fixture#, part#, etc. It's a fair amount of text on EACH pocket.
I am using inventor to generate the model, and EdgeCAM 2009 (I'm hoping to have 2010 R1 installed sometime this year... a whole other story).
I can emboss the text, but I'm using a 3/8" router bit to cut the pockets and would like to cut the text with that also. Making the text large enough to fit a 3/8" router into makes it too big to fit into the space I have (don't even get me started on not being able to cut a 3/8" slot with a 3/8" tool due to links/leads).
I cannot leave the text in a sketch, Edgecam doesn't import sketch geometry. I can't export the sketch as .dwg or .dxf, the text doesn't get exported. I can't use text mill on embossed text.
I have called Inventor tech support and Edgecam tech support, and both are flummoxed.
I don't really care what the solution is, as long as I don't have to profile the whole embossed text and cut all the edges, or draw centrelines for everything.
Anyone have any ideas? How do you cut text in EdgeCAM?
