Just starting the electronics for the lathe I am building. (http://cnczone.com/forums/showthread.php?t=92337)
G540, Mach3
G540 fault LED is lit. If I switch charge pump switch to off fault LED goes out and power LED is lit.
I switched the charge pump switch off and hooked up a motor and got it to spin by jogging in Mach3 so I'm assuming (uh oh) that the computer/parallel port is configured correctly.
In Mach3 I went into config >> ports and pins >> output signals and enabled the charge pump on port 1, pin 16. The active low is off (X) but I tried it both ways.
Where do I go from here? Should this be in the Mach3 area instead?
