Images not workingHello
I had purchesed a microkinetics CNC lathe and the threading the program times out waiting for the Encoder. So Jeff had helped me and the wireing is correct and stuff and i had entered the correct gcode for the program and it runs fine in the simulator but when in machine mode it doesn't.
So i had took off the encoder and the red light / Laser turns on when the program is ran but doesn't turn off even if you turn off even if you stop the program.
I had also noticed 2 diffrent size spots on the disc they are diffrent in size and are light brown.
Is this the problem.
Also do any of you have any ideads on how to convert the MN400 Drive rack I'd like mach 3
Please see Images below if you know where to get this encoder please leave a post thanks Austin
Attachment 101490
Attachment 101491
Attachment 101492
Attachment 101493
