586,817 active members*
6,607 visitors online*
Results 1 to 9 of 9
    Apr 2008
    51
    Any improvements on my X-axis?
    My X axis, rather the router has too much play in it along the X axis. I previously had a ball screw mounted in between the 2 rails, but that seemed to act as a pivot. I just switched it to rack and pinion both top and bottom so see if that would eliminate the play, it didn't. I am game for completely redoing the X axis, but I don't know what would make the router extremely stable.
    Ben
    Shoot, I can't upload any pics which would really help out this post.
    Jan 2008
    853
    Is the gantry racking (one side moving ahead of the other) ? If so, look for the posts on avoiding racking using a sliding knot configuration of thin SS wires running across the gantry and anchored on the frame. It seems to work wonders.
    If by play you mean looseness, the solution depends on if the play on the X axis is in the X, Y or Z directions ...
    Cheers!
    pr
    Mar 2009
    624
    Pics would really help, check file size and keep it below 1000kbs should work then.
    Apr 2008
    51
    My pics
    Here is a picture of my current setup for the X-axis. I feel like there is too much movement along the X-axis, however after testing it today, my cuts seemed to be acceptable. I still wish it was rock solid, perhaps the rails allow for too much play? Or maybe I need to mount the rails in a vertical fashion so that I can "sandwich" them?
    Ben
    Mar 2009
    624
    Can you re-size and post again, it's so small cant see it properly.
    Dec 2008
    226
    Well you went and got some nice supported rail, but it isn't actually supported by anything... where there is a mount surface, there is only a fastener on one side of the rail base... The double rack and pinion looks solid, but wouldn't a second bearing on the rail give a wider stance and more stability?
    Jun 2004
    6618
    I agree the rails need another beam back there for some support. Double up on the bearings too as mentioned.
    Should be much more solid that way.
    Lee
    Mar 2009
    624
    Thats better can see know.
    A few points i would change, unfortunatly it would mean a nearly rebuild of the Z axis.
    1: I would make Z wider with 2 bearings like Pandinus say's this will help lots and i would only use 1 R&P dont think 2 is neccesary and just adds to the friction robbing power.? Also could cause problems with not getting racks aligned perfectly causeing all sorts sticking and alignment issue's.
    2: Definatly need to support them rails with braces fastened to uprights.
    Apr 2008
    51
    Well, I gave myself a wider stance, 4" to 8" and I left myself access to the screws in the pillow blocks. I always thought those were there to hold the bearings in the block, apparently you can adjust the tension of the bearings.
    I tried to post a pic, but it doesn't want to work again. And yes the files is small enough...
    I'll have to test the machine tomorrow to see if that fix removed some of my play.
    thanks,
    Ben
  1. Owners manuals need improvements!
    By AMCjeepCJ in forum Milltronics
    Last Post: 11-22-2009, 05:34 AM
  2. X2 Mods - additions and improvements to an X2?
    By mnbylcr2 in forum Benchtop Machines
    Last Post: 05-24-2009, 01:06 AM
  3. What improvements/suggestions for EMC2, if it was up to you?
    By chester88 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-15-2009, 10:00 PM
  4. Taig Headstock Improvements??
    By scubasteve_911 in forum Taig Mills / Lathes
    Last Post: 08-22-2007, 06:10 PM
  5. More Improvements
    By rodneydeeeee in forum Dolphin CAD/CAM
    Last Post: 03-22-2007, 10:40 AM
