586,690 active members*
3,015 visitors online*
IndustryArena Forum > CAD Software > Solidworks > converting a .sldprt solidworks file into a .stp or parasolid file
Results 1 to 9 of 9
    Feb 2010
    im using solidworks2009 and i need to convert my part file into a .stp or parasolid file.. i believe its going to be put into mastercam not entirely sure.. but any help on how to do this will be greatly appreciated
    Aug 2008
    199
    use, save as, specify parasolid or step
    for CNC woodcarving - 3d puzzle - furnitures
    http://pagesperso-orange.fr/fabrun/
    Feb 2010
    all i can save it as is .sldprt edrawing and 2 other other ones... am i missing something? i do only have an education version of it so that might be a problem also
    Aug 2008
    199
    you're right
    i can translate it for you if you want
    Oct 2008
    2100
    Re: converting a .sldprt solidworks file into a .stp or parasolid file
    Bob La Londe
    http://www.YumaBassMan.com
    Dec 2008
    3112
    Quote Originally Posted by avogtster View Post
    Yes, the educational versions can be restrictive in what data is transferable ( ie the source software may not export the desired format, the destination software may ( also being educational ) may also have options "greyed out"
    - but that being said
    Mastercam can import Solidworks files directly, the limitation is that the .sldprt file is from the same or earlier year, than the destination software ie 2009 .sldprt file cannot be opened by a earlier Mastercam X4 or X5 version
    Step(.stp) / Iges(.igs) / Parasolid(.x_t) - These formats are fairly reliable ways to exchange solid models between various software
    --- stay away from stereolithic (.stl) formats, Their shapes can be altered be the accuracy setting when exporting & importing. So the final shape cannot be guaranteed to be the same as in the original design
    Just looked at the OP date---- 5 years ago
    THIS POST IS LONG DEAD
    Oct 2008
    2100
    Go to my link and read my post. It gives you a way to convert from sldprt to other formats.
    Bob La Londe
    May 2015
    4
    just Save As - to file type you want
    Dec 2008
    3112
    look at the OP date---- 5 years ago
  1. converting a solidworks file to g-code
    By JoeyB in forum Australia, New Zealand Club House
    Last Post: 05-15-2015, 11:53 PM
  2. Solidworks .sldprt file format
    By kanzure in forum Solidworks
    Last Post: 03-07-2015, 10:37 PM
  3. SLDPRT FILE WON'T OPEN!!V22
    By notchtopper in forum BobCad-Cam
    Last Post: 11-05-2011, 03:26 PM
  4. ERROR Cannot find parasolid data in solidworks file?
    By blakemachine in forum Mastercam
    Last Post: 12-04-2010, 05:49 AM
  5. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
