Originally Posted by
GLCarlson
I'm trying to make sense out of the pictures of the manual drawbar.
Ray, I hope I haven't made things more confusing.
The motor drive is mounted to the spindle enclosure, on a platform above the spindle attached by a post to the 1100 motor base and into a slotted holder attached to the sheet metal shroud. The drive screw is suspended above the hydraulic actuator of the LOD, and pushes down on it when actuated. There is nothing that clamps around or supports the bottom of the hydraulic actuator - the actuator rests only on the top of the spindle. The motor drive pushes the hydraulic LOD assembly against the spindle. The pressure required and the effect on bearings was a concern I had.
Earlier in this thread, Scott M and others explained that the 2500 lb force is exerted against the top of the actuator, and that the spindle bearings see only the roughly 300 lb drive force. I think that must be so, since the linear actuator I used is unable by itself to compress the washer stack. It claims only 900 lb of force.
Chris D
You're entirely welcome, and I hope this is useful either as a take-off point for a better design or as it stands. Incidentally- I think one could, if one wanted to be very finicky, build it without the latching relays, using the cam and an extra two microswitches. The relay approach seemed to me to be about the same cost and easier to implement, as one of my design goals was low-precision.
glc
