For marking steel, does anybody can help me understand the difference, pros and cons of the plate marker from Torchmate and the Arc Writer from Hypertherm?
Or the comparison should be between the Arc Writer and the Routing/Drilling acesory from TM?
I believe the arc writer uses an electrical arc to effectively gouge the material, leaving a small depression in the material where the torch moves. The Plate marking attachment uses pneumatic air pressure to push against the material with a vibrating tip leaving a small, clean depression in the material.
I like the Plate Marker for it's accuracy and consistency, as well as the speeds you can travel at with it. It's a fair bit on the noisy side, just a fair warning!
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Thanks fof the quick answer, I assume the scribe is the marker from TM.
If so, you believe the Arc Writer is not as accurate and as consistent as the marker?
And, does TM offers as well the Arc Writer from Hypertherm?
