587,081 active members*
2,628 visitors online*
    Oct 2010
    Fagor 8055 and edgecam
    Hello, I need help, how to generate a nc in EdgeCAM fagor for 8055??
    Oct 2009
    47
    I am not sure about Edgecam, I use Surfcam, but you should be able to generate the Gcode but then save it as ".pim" file, not your typical ".nc" file. You can get a program from Fagor Automation called WinDNC. With this program you can down load the ".pim" file to the controller.
    Hope this helps.
    Motion Master 5 Axis Router.......Fagor 8055/C.......Surfcam Velocity 4.0 B189
    Oct 2010
    obridado response,
    yes, I generate the CODIGOG in the generated code needs to make some adjustments, save in 000.pim Seems magic and ready ...
    hehehhe
    ok
    Jul 2008
    67
    For best ease in downloading/uploading programs, I do recommend you utilize the Fagor DNC program..... it is free of charge and can be downloaded in just a few minutes from the download center at Máquina herramienta, Medición, Motion control, Energía : Fiabilidad en todo el mundo : CNC, DRO, encoders, reglas, inversores de corriente, servosistemas
    That program makes uploading/downloading, plus monitoring very simple.
    hope this helps
    Todd
  1. Fagor 8055 DNC communication
    By theartz in forum Fagor Automation
    Last Post: 01-12-2011, 11:13 PM
  2. HELP POSTING TO FAGOR 8055
    By rough_cut in forum Fagor Automation
    Last Post: 04-21-2010, 02:08 PM
  3. Error on Fagor 8055
    By carving123 in forum Commercial CNC Wood Routers
    Last Post: 01-18-2010, 02:44 PM
  4. Fagor 8055 Control
    By ChadK in forum Fagor Automation
    Last Post: 07-01-2009, 10:54 AM
