587,935 active members*
4,216 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Error Machine XML file
Results 1 to 10 of 10
    Jun 2012
    393
    Well I am getting an error when I try to run the Sim. Error reading XML file. I had a Bobcam tech try and help but he could not. Before I reinstall Bobcad again I would like to see if anyone has fixed this problem. I can see all of the Xml files in the folders Bobcad cannot see them. I checked the paths in the mill sections and they are pointing to the correct paths. LOST LoL.
    Thank You
    Don
    PS I can Post and save the TP and Mach 3 can run them.
    Mar 2012
    1570
    What machine definition are you use? I would try just using the default bc3xmill and see if the problem goes away. My thoughts are you made some change the the machine def and that is why you are having an issue.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jun 2012
    393
    I guess I forgot the part about contacting tech support and they could not help. They even logged into my computer. He gave up and suggested a reinstall. I was hoping to avoid that. This will be a third install of the software and I would need to go through the validate game again. All this of course means lost time and effort. I just want to use the program. Aside from all this is the constant crashing. It appears that Bobcad is not running under windows 8 very well.
    Thank You
    Don
    Jun 2012
    393
    I did fix the problem. I do not need to reinstall the software.
    Thank you
    DOn Murphy
    Apr 2009
    3376
    I have used Bob for 4 years,2 different versions,did a re-install once,but it was not needed.Thought I needed to do re-installs about a dozen times.Nope.Usually something easily fixable.
    Dec 2008
    4548
    Shhhhhhhhh.... It's a secret..
    Apr 2009
    3376
    Now,I have gone back a build before,,but that's a whole different thingy.
    Quote Originally Posted by Gallchobhair View Post
    What was the problem?
    May 2013
    701
    Wait for it, Wait for it, OK already
    Jun 2012
    393
    The problem was : I could not get the sim to run. Error creating XLM or reading xml file. Solution after calling and getting tech support. Having them log into my computer then telling me to re-install Bobcad, was to move the xml file to where bobcad was looking. I do not know which xml it was looking for I just moved all of them.
    Don
  1. File read Error?
    By atbjake in forum CamSoft Products
    Last Post: 11-26-2011, 10:06 PM
  2. Error in XilogPlus.ini File
    By ktamas in forum CNC Machining Centers
    Last Post: 11-05-2011, 03:30 PM
  3. plt file error
    By Dermot in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-14-2010, 04:49 PM
  4. File Error
    By justbrowsing in forum Mastercam
    Last Post: 02-26-2009, 03:25 AM
  5. error of inport file
    By reed in forum Torchmate
    Last Post: 08-05-2008, 07:39 AM
