Basically I have multiple doubble vices and I am making the same part multiple times in the machine at the same time. The part is already programed to one work offset. I know I can just copy the g-code and copy the program to the end of the program and just change the work offset for each additional part I want made in the same cycle. What I am trying to do is eliminate the tool changes. Is the only way to do this is manually copy and pasting the code for each tool on the g-code. Does mastercam have a built in better way? I am using X4.
