587,236 active members*
3,591 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Haas VF, Mini-Mill and Toolroom ATC Carousel Disk Upgrade CAT40/BT40 10-20 Tools
    Sep 2009
    9
    CAT40 20 Tool
    CAT40 10 Tool
    Replace your OEM cast tool disk!
    Visit http://www.buycmi.com for more information or call 517-529-9454.
    Clarklake Machine, Inc. - Precision Machining and Assembles
    http://ClarklakeMachine.com - 517.529.9454
    Sep 2006
    1738
    That is a thing of beauty.
    Sep 2009
    9
    Lessen the Severity of Carousel Crashes
    By Charles Bates | For the American Machinist | Penton Media, Inc.
    American Machinist Articles
    Severe machine crashes seem to be inevitable, but now, when they happen, shops can replace only the damaged segments of a vertical machining centers tool disk instead of the whole carousel-type disk. What makes this possible is a retrofitted CMI Segmented Tool Disk from Clarklake Machine Inc.
    Often, after crashes due to accidents, machine malfunctions, operator errors or taper locks caused by debris or heat, operators must replace a machines entire one-piece stock tool disk. The CMI tool disk, made for Haas VF-Series CAT-40 20- tool machining centers, incorporates individual segments that are attached to a base plate and are replaceable.
    The tool disk is made of precision-machined 6061-T6 billet aluminum. If the segmented disk becomes damaged, only the effected segments are replaced. Preassembled, the 21-piece unit has 20 segmented tool pockets and one base plate. This is also a "green" technology that helps reduce the overall carbon footprint of high-tech CNC equipment.
    CMI Segmented Tool Disks feature removable segments that allow shops to replace only damaged portions after a machine crash.
    CMI News
  1. CAT40 vs BT40 tool holder????
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 01-27-2011, 04:45 PM
  2. Mini-Mill Segmented Tool Disk Upgrade CAT40 10-Tool
    By C.M.I. in forum News Announcements
    Last Post: 12-17-2009, 07:36 PM
  3. Carousel Disk for Haas VMCs
    Last Post: 11-20-2009, 09:16 PM
  4. ABOUT HAAS Toolroom mill 1H
    By marto74 in forum Haas Mills
    Last Post: 09-12-2009, 07:06 PM
  5. BT40 holders in CAT40 machine? does it work...
    By RedGTZ in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2008, 05:08 PM
