I have tended to buy high end VFD's on ebay such as WEG, Mitsubishi, Telemecanique.
The thing that I have noticed with R.O.C. equipment is the lack of electrical safety aspect, in the instance you show, the spindle motor should have a 4 pole connector to accommodate the ground conductor.
Not leave it to connector shell etc.
Another example on a previous post showed a power supply with live 120vac socket with male pins, instead of female sockets outlets.
Al.
