587,920 active members*
3,409 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Cross reference for transistor on Glentek amp
Results 1 to 7 of 7
    Jan 2007
    17
    I have a Gentek servo amp made for Anilam in the early 1980's model GA4561, there are four transistors on this and I know at least one of them is bad. Transistor is a GTK45583, replacement transistor is GTK45578 at $90.00 each, anyone know of a suitable replacement for this transistor.
    In my google search I have found these transistors and possible replacements, MJ10020, MJ10015 or MJ11032.
    This amp is running a SEM MT30 servo motor, 75 vdc.
    Any help I could get will be greatly appreciated,
    Bruce
    Attached Thumbnails Attached Thumbnails Servo amp front.jpg   Servo amp back.jpg
    Jun 2003
    866
    it's likely that this is being run in PWM, if so then a lot of transistors would probably work, possibly with some changes in resistors.
    24220
    If you can find the data sheet on the GTK's and find out if they are power darlingtons, as the MJ11032 are, and are a replacement for the type used in the Westamp similar amp.
    But I think I have read somewhere the GTK's are different technology? IGBT's ?
    Al.
    Jun 2003
    866
    looks like that is actually a glentek part number, so you want a replacement that isn't.
    Jan 2007
    17
    They want $90.00 each for the Glentek transistor so yes I am looking for a non Glentek replacement.
    Looking at the 3 amps I have, each has 4 GTK45583 transistor, I just noticed one transistor of the 12 total is a Motorola 2N3773, see first transistor in first photo. I'm going to to replace the one known bad one with a 2N3773 and see how it goes.
    Jan 2009
    334
    NPN 2N3773*, PNP 2N6609
    Quote Originally Posted by bmklawt View Post
    Data sheet for 2N3773; http://www.onsemi.com/pub_link/Collateral/2N3773-D.PDF
    Good Luck,
    Iron-Man
    Jan 2007
    17
    I replaced the 4 GTK45583 transistors with 2N3773 and the amp is now working.
    I bought the transistor from www.digikey.com/scripts/dksearch/dksus.dll?vendor=0&keywords=2n3773+ about $4.00 each
  1. Craftsman router collet cross reference?
    By johnmac in forum DIY CNC Router Table Machines
    Last Post: 12-12-2008, 10:08 PM
  2. cross reference servo drive help
    By vesteroid in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2007, 03:14 PM
  3. Retention Knob Cross Reference for 50 Taper?
    By pdoherty in forum Haas Mills
    Last Post: 12-14-2006, 05:54 AM
  4. diode cross reference
    By messar in forum CNC Machine Related Electronics
    Last Post: 12-09-2006, 01:43 AM
  5. Shoptask Bearing Cross-reference?
    By Jasonixo in forum Shopmaster/Shoptask
    Last Post: 04-17-2006, 03:12 PM
