Originally Posted by
Gunni
Can I use the polyester resin to level my x-axis (the table where my PRO4896 shall be on) instead of the epoxy?
Casting polyester seems to have a very low viscosity and is self leveling and it is very common, I have a hard time finding epoxy.
All I can figure out is that epoxy is a little stronger but is it necessary?
I don't see a problem with it but it sounds like a lot of work. I can't tell from your post if you mean the bed of the router or the workbench it's going to sit on.
If it's the bed, you are much better off just using a standard material like MDF, plastic, or aluminum and facing that directly with the router. You want something that is level with the plane of movement and if that machine isn't precisely leveled gravity will pull your cast table out of position.
If it's the workbench the router sits on, why not just go with leveling feet?
Nate
Fine Line Automation
Home - Fine Line Automation
www.finelineautomation.com
