587,460 active members*
3,504 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > System Alarm no. 3 Program Memory : PARITY HIGH
Results 1 to 9 of 9
    Dec 2011
    Alarm message " Parity High " appeared after turning - on the machine . Machine control is FANUC SYSTEM 3T . All function keys are disabled .Help me guys!!!Thanks
    Sep 2010
    125
    only one way....Complete clear...
    parameter enable switch on (upper right on main board)
    press reset and delete at power on,
    you now have to enter all data !
    good luck
    Aug 2011
    2517
    let's hope he did a backup of all parameters prior to this event otherwise we'll see him here again asking if anyone has a 3T parameter backup
    Sep 2010
    125
    I think so .... but it's too late for thinking !!!
    Dec 2011
    Thank you TMBRUNO28 for your good advice,it was really appreciated but Reset + Delete at power -on also not work instead , i used " P + CAN + DELETE " at power-on . All parameters had been reload machine is OKAY now. Thank's guys !!!
    Jul 2013
    hi i have a Eumach V-24 VMC i need operators manual for it to know which g-codes and m-code it uses with sample programs, if any one have please help me and share
    Aug 2010
    32
    I am having this same issue. If I clear memory, where do I find the parameters to manually put back in? Thanks
    Aug 2010
    32
    Dec 2019
    I just had the same issue and did the total reset. Reloaded parameters but I'm missing my radius and tool type columns in my tool offset table now. Any help on this? Thanks!
  1. 911 ram parity high on FANUC 0T mate
    By gunawan_tehnik in forum Fanuc
    Last Post: 03-28-2022, 12:21 PM
  2. system alarm 904& bubble memory
    By sting007 in forum Fanuc
    Last Post: 05-19-2021, 07:21 PM
  3. ALARAM 22 MEMORY PARITY ERROR
    By tonny2105 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-20-2012, 07:48 PM
  4. C-MOS PARITY ALARM, FANUC 3 M
    By JGPerry in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2008, 12:47 PM
  5. How to erase ALL T2 OP parameter and 22 NMI Memory Parity problem?
    By Donatello Tam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-14-2007, 06:01 PM
