OK, so I'm trying to integrate Mach 3 + KFlop + Kstep into my first mill build (BF20 Vario L) and so far I am able to jog and run Gcode in KMotionCNC, however I'm encountering a problem when i try the same in Mach3. At first, everything seemed to run fine but after i tuned the motors in Mach3 to the desired parameters, moving the Y axis keeps kicking me into emergency mode.
The X and Z axis jog fine but when i jog the Y axis, it get's up to speed, runs at max speed for 1-2 sec and then it stops when the "emergency mode" activates it self.
It isn't a mechanical obstruction because the motors are still on my desk and not attached to anything.
It isn't a defective motor/cable because i swapped the X and Y motor and the problem still occurs on the Y axis on the swapped motor.
It isn't a power problem because the power supply is at 42V 18A, and the motors are 3A each.
It isn't a max speed/acceleration problem because I'm running the motors at modest parameters.
It doesn't matter if all motors are running or the Y axis alone, the problem occurs the same.
No limit switches or E-stop buttons have been attached to the system or configured yet.
The problem does not occur in KMotionCNC.
Any ideas?!?!?!?!
