587,446 active members*
3,123 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Connecting Breakout board to Stepper Drivers
    Apr 2013
    Hi, I bought a Breakout board and stepper drivers to change my 3 axis TB6560, but I don't find the connection schema
    My breakout board
    Attachment 182998
    And drivers ...
    Attachment 183000
    Thanks a lot
    Jan 2007
    467
    leprosylv,
    The only pins that the breeakout board will connect to on this motor control will be the Step, Direction, and the two COMMON pins (S- and D-). The motor will connect to the drive itself as will the power supply. It looks like the breakout board is wired to have the right side of the board (in the picture) be used for the control outputs. You will assign these manually in the software you are using to act as your Step and Direction outputs.
    Did this breakout board come with an XML file that automatically assigns the DB25 pins? If so, they will be labeled as "X- Axis Step", "Y-Axis Direction", etc.
    Marcus Freimanis
    Apr 2013
    I don't understand your answer
    Jan 2007
    467
    You will want to use the top part of that diagram they provided (the one that says 1"is defined and parallel control:"). Run a wire from P2 to STEP+ on your driver and a wire from P14 to DIRECTION+ on your driver. The STEP - and DIRECTION - will connect to the GND pin right next to P14.
    After this is connected you can declare the pins in your software as your X-axis step and direction outputs. All you need to do then is connect the motor and power supply to your drive and it should run just fine.
    Marcus Freimanis
    www.geckodrive.com
    Apr 2013
    If I understand, I don't need a breakout board ?
    Attachment 183752
    Jan 2007
    467
    Technically you would not need a breakout board but it makes life MUCH easier. I am not sure what the acceptable logic inputs for that drive are but a parallel port will only output 3.3V logic; if your drive cannot accept that then you will need a breakout board to buffer the signal. We always recommend them with our drives because a breakout board serves a twofold purpose: Signal buffering and computer isolation. If your drive goes out it could potentially take out part of your computer as well as there is a decent amount of power being dissipated in a motor control failure.
    Marcus Freimanis
    www.geckodrive.com
  1. Need HELP connecting Hypertherm 105 to Breakout Board
    By HIDesigns in forum Waterjet General Topics
    Last Post: 08-28-2015, 08:52 PM
  2. Connecting Breakout board to Stepper Drivers
    By bleker in forum Stepper Motors / Drives
    Last Post: 07-08-2014, 10:03 PM
  3. Wiring breakout board to old Isel Stepper drivers
    By TashadraCPT in forum Stepper Motors / Drives
    Last Post: 08-29-2012, 06:40 PM
  4. Wiring breakout board to old Isel Stepper drivers
    By TashadraCPT in forum CNC Machine Related Electronics
    Last Post: 08-28-2012, 11:07 PM
  5. How to connect breakout board to stepper motor drivers?
    By jeffmorris in forum Stepper Motors / Drives
    Last Post: 06-27-2012, 09:25 PM
