587,281 active members*
3,240 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > slicing 3D model for Laser/manual LOM
    Jun 2014
    39
    I have a couple projects where I have a 3D model and would like to laser cut and manually stack up layers of corrugated cardboard.
    One is a terrain model. The other is a lampshade, the light through the shade will be an interesting pattern.
    I'm looking for software that takes in 3D (In whatever format), and puts out a 2D path. So I'd be turning a 3D model of the land into, effectively, a contour map, as a 2D dxf or ai or svg or some such.
    I can use Aspire to slice the 3d model, and generate a profile path, but that's slow, one at a time.
    Any suggestions?
    Nov 2004
    164
    Re: slicing 3D model for Laser/manual LOM
    You might try looking at some of the resources for 3D printing. I think that is the manner in which they operate, by breaking up the .stl file into slices. I see that a program called OpenSCAD can di it, but you might have to find or write a script to automate it a bit for your needs ( OpenSCAD User Manual/3D to 2D Projection - Wikibooks, open books for an open world ). Another such program I see is slic3r ( Slic3r - G-code generator for 3D printers ) which produces g-code maybe that works better to program the laser directly.
    Nov 2004
    164
    Sorry about the double post, can someone tell me how to delete it?
    Jun 2014
    39
    Thanks for the openscad pointer. I can probably write a program to make a bunch of dxf files, then read them.
    I'm also experimenting with getting a grayscale heightmap, then tracing it in illustrator.
    Nov 2004
    164
    Upon further review it looks like that Slic3r program does .SVG files as well as the G-Code
  1. g.weike laser new model laser STORM5030
    By g.weike laser in forum G.Weike Laser
    Last Post: 06-30-2014, 01:37 PM
  2. Slicing 3D model
    By Gallchobhair in forum BobCad-Cam
    Last Post: 04-28-2014, 08:50 AM
  3. Slicing up a thick model
    By bearwen in forum BobCad-Cam
    Last Post: 07-01-2012, 03:29 PM
  4. cut3D Slicing Model Fix
    By Easydad in forum Vectric
    Last Post: 05-18-2009, 11:12 PM
  5. Replies: 11
    Last Post: 02-05-2008, 10:34 AM
