587,657 active members*
5,736 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > In Bobcad 21, how do I draw up a lathe piece
    Mar 2007
    125
    I have just built a CNC lathe, and it is working very well, except that I have had to make my drawings like I do for my mill, IE, setup an X axis and a Z axis. While that is working, some of the 3d cuts are getting to be a pain, I'm relatively certain that Bobcad can do lathe stuff, but don't know how to do it. Also, I have never used mach3 Turn, anyone have some pointers on that?
    Jun 2003
    446
    What version of BobCAD-CAM software do you have? I'm sure that we can help you with anything you may run into quickly.
    CNC Dude
    Aug 2003
    449
    Here is a link to the Lathe pdf file. It should help get you in the right direction. Post if you have any issues or questions.
    The link says Version 19, but nothing changed between V21 and 19 as far as lathe is concerned.
    Regards
    http://www.bobcadsupport.com/tech//m...the_Manual.pdf
  1. BobCAD 2007 Mill and Lathe!
    By nlh in forum BobCad-Cam
    Last Post: 09-09-2007, 11:17 PM
  2. Replies: 3
    Last Post: 12-24-2006, 04:41 AM
  3. RFQ: Lathe work, one piece.
    By SCCoupe in forum Employment Opportunity
    Last Post: 07-24-2006, 11:58 AM
  4. RFQ for Two Piece Lathe & Mill Work
    By stang5197 in forum Employment Opportunity
    Last Post: 02-21-2006, 04:17 AM
  5. RFQ Custom Lathe Piece
    By Cold Fusion in forum Employment Opportunity
    Last Post: 04-05-2005, 06:09 AM
