587,263 active members*
3,453 visitors online*
Thread: Tsc problems
    Jan 2007
    4
    Thumbs up Tsc problems
    Hello people im new here.
    I work for a while now with a my 2000 vf2,and having troubles with tsc im
    getting the 151 alarm (low thru spindle) ive checked all inlets and the cooland tank and no luck.
    Im familiar with using cutters with smaller holes so thats not the problem.
    Is it possible the pressure sensor is broken?
    Aug 2005
    578
    either a sensor or a filter issue I'd think
    Sep 2006
    51
    I would try to run without a tool in the spindle.When I don't use TSC for few weeks it needs a startup. I just go to MDI , close the door and press AUX CLNT.
    If it does not help fliter is next, then sensor.
    Jan 2007
    4
    Thanks for the replies, ive had the spindle cover off and changed all filters.
    From what u guys said must be the pressure sensor.
    There has been prolems with it since it was new,has been a mechanic from haas two times and he could not solve the problem.
    Does anyone know how much the check valve (last one before the spindle coolant) costs?
    Grtz
    Feb 2007
    TSC Problems
    You might try looking at your TRP Assy to be sure it is properly set. I have seen this before also.
    Good Luck!
    Jan 2007
    4
    Smile
    Quote Originally Posted by HaasTech View Post
    Good Luck!
    Thanks i had another problem with the vf2 today shuttle fault, so convinced my boss too call the local haas outlet..
    the mech will take a look at the trp also,im too busy too check it out myself
    anyways and dont know enough about it too.
    Thanks for your reply
  1. Tap Problems
    By Skeeterd5150 in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2006, 09:12 PM
  2. Problems
    By vebers in forum Servo Drives
    Last Post: 05-03-2006, 05:59 AM
  3. More problems
    By Cold Fusion in forum Gecko Drives
    Last Post: 09-09-2005, 07:19 AM
  4. my first pcb, problems please help.
    By NickLatech in forum DIY CNC Router Table Machines
    Last Post: 03-17-2005, 05:51 AM
  5. 85 vmc 40 problems
    By tractdesign in forum Fadal
    Last Post: 01-17-2005, 11:15 PM
