587,172 active members*
3,032 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Help with adding subprograms to post processor
Results 1 to 10 of 10
    Jul 2005
    195
    I'm want to add subprograms to my post processor.
    As the supplied post didn't support subprograms, I've started to change the standard MPFAN post to suit. This has worked very well so far but I'm having to move the subprograms from the end of the G code program upto the start of the program manualy.
    I would really like to change this to it automaticly in the post.
    Any help would be greatly appriated
    Cheers
    Chris
    Jul 2005
    195
    Update
    I think I've found the code that puts the subprograms in, well if I move MERGEAUX up a couple of lines i.e. above line n, "M02", e. Then the subprograms are placed above the line containing M02 but when moving MERGEAUX so it is just below the program no. i.e. below line *progno, e. The subprograms dissapear totaly.
    Chris
    Jul 2005
    195
    Still can't do it.
    Someone help please even if you just tell me it is not possible.
    Cheers
    Chris
    Apr 2004
    34
    Hi Chris, for sure that is possible. Mastercam has a great handling with subprogs. But in order to define them into your post, it´s very complicated. It depends on a lot of variables and settings inside the post. The answer for you question is not so simple, not even short. but yes, is possible to get subprogs in Mastercam (And they works perfectly when proper configured in the post), but is complicated to define them also. Get in touch with your dealer and ask for him about the MP Guide, available in CD-ROM.
    Cheers
    Kind Regards
    Daniel - Camfun
    Jul 2005
    195
    Thanks for the reply, I'll look out for the CD.
    Just thought someone would be using subprograms on a brigdeport with there very limited memory and there been so many of them around.
    Cheers
    Chris
    Aug 2005
    149
    I have a post but it's for a fanuc if you like I can e-mail it to and maybe you could get an idea of how they are used and edit your own pp I have mine just the the way i like it..
    just pm me and i'll e-mail it to you.
    here is a sample of how it posts.
    O0015(ITEM 1 -OP2 WHAT HAPPEN FIXTURE.NC)
    (DATE= 16-03-06 TIME=17:29)
    (DRILL)
    ( 1/4 SPOTDRILL TOOL - 1 DIA. OFF. - 31 LEN. - 1 DIA. - .25)
    N1G0G40G49G80G90Z0
    M107
    T1M6
    G54X-.3001Y-3.4943S6000M3
    M8
    G43H1Z.2M8
    M98P0001
    (DRILL)
    G90G55X-.3001Y-3.4943
    Z.2
    M98P0001
    (DRILL)
    G90G56X-.3001Y-3.4943
    Z.2
    M98P0001
    G90G54X.21Y-2.745
    Z.2
    M98P0002
    G90G55X.21Y-2.745
    Z.2
    M98P0002
    G90G56X.21Y-2.745
    Z.2
    M98P0002
    G0Z1.M9
    G49Z0M5
    G28G91Y0
    M01
    (10-32 PILOT HOLES)
    ( #21 DRILL TOOL - 2 DIA. OFF. - 32 LEN. - 2 DIA. - .159)
    N2G0G40G49G80G90Z0
    M107
    T2M6
    G54X-.3001Y-3.4943S3000M3
    M8
    G43H2Z.2
    M98P0003
    (10-32 PILOT HOLES)
    Z.2
    M98P0003
    (10-32 PILOT HOLES)
    Z.2
    M98P0003
    G0Z1.M9
    G49Z0M5
    G28G91Y0
    M01
    (6-32 PILOT HOLES)
    ( #36 DRILL TOOL - 3 DIA. OFF. - 33 LEN. - 3 DIA. - .1065)
    N3G0G40G49G80G90Z0
    M107
    T3M6
    G54X.21Y-2.745S6000M3
    M8
    G43H3Z.2
    M98P0004
    (6-32 PILOT HOLES)
    G90G55X.21Y-2.745
    Z.2
    M98P0004
    (6-32 PILOT HOLES)
    G90G56X.21Y-2.745
    Z.2
    M98P0004
    G0Z1.M9
    G49Z0M5
    G28G91Y0
    M01
    (10-32 PILOT HOLES TAP)
    ( #10-32 TAPRH TOOL - 4 DIA. OFF. - 34 LEN. - 4 DIA. - .19)
    N4G0G40G49G80G90Z0
    M107
    T4M6
    G54X-.3001Y-3.4943S1000M3
    M8
    G43H4Z.2
    M98P0005
    Z.2
    M98P0005
    Z.2
    M98P0005
    G0Z1.M9
    G49Z0M5
    G28G91Y0
    M01
    (6-32 PILOT HOLES)
    ( #6-32 TAPRH TOOL - 5 DIA. OFF. - 35 LEN. - 5 DIA. - .138)
    N5G0G40G49G80G90Z0
    M107
    T5M6
    G54X.21Y-2.745S1000M3
    M8
    G43H5Z.2
    M98P0006
    (6-32 PILOT HOLES)
    G90G55X.21Y-2.745
    Z.2
    M98P0006
    (6-32 PILOT HOLES)
    G90G56X.21Y-2.745
    Z.2
    M98P0006
    G0Z1.M9
    G49Z0M5
    G28G91Y0
    M30
    O0001
    G81G98Z-.1R.1F20.
    Y.0857
    X5.2799
    Y-3.4943
    G80
    M99
    O0002
    G81G98Z-.07R.1F20.
    Y-.62
    X4.82
    Y-2.745
    G80
    M99
    O0003
    G83G98Z-.6R.1Q.1F15.
    Y.0857
    X5.2799
    Y-3.4943
    G80
    M99
    O0004
    G83G98Z-.6R.1Q.1F18.
    Y-.62
    X4.82
    Y-2.745
    G80
    M99
    O0005
    G84G98Z-.5R.15F31.25
    Y.0857
    X5.2799
    Y-3.4943
    G80
    M99
    O0006
    Y-.62
    X4.82
    Y-2.745
    G80
    M99
    Jun 2005
    305
    It would be easier to start with a post that already supports subprograms.
    Then modify it to suit your machine and controller.
    I'm pretty sure the Fadal post supports subprograms as you describe them.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Mar 2006
    1013
    If your using a current MPFan (V9 & up) it already supports subs. It's all in what you pick on the Parameter page, when your doing your toolpath.
    Contour: Pick Depth Cuts and check the Subs box.
    If your doing a toolpath Transformation. Same thing. Look for the Subs check box.
    You shouldn't have to modify the post to get subs. You might need to modify it for a particular format, but it should be there already.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Jul 2005
    195
    Thanks for the comments even though most of you got the wrong end off the stick, I do still appreciate the help.
    A big thanks to ObrienDave thats exactly what I was after, I just copied loads of that post into mine not really sure which bit made it work but it does so I'm happy.
    This is what I wanted to get (simple program milling a square a few times for a example)
    #1
    N112X50.
    N114Y0.
    N116X0.
    N118Y50.
    N100G71G17
    N102G0G90T1M6S1909
    N104X0.Y50.
    N106Z50.
    N108Z2.
    N110G1Z-2.F382
    =#1
    N120G90Z-4.
    =#1
    N130G90Z-6.
    =#1
    N140G90Z-8.
    =#1
    N150G90Z-10.
    =#1
    N160G0G90Z50.
    N162M02
    What I was getting before which doesn't work
    N100G71G17
    N102G0G90T1M6S1909
    N104X0.Y50.
    N106Z50.
    N108Z2.
    N110G1Z-2.F382
    =#1
    N120G90Z-4.
    =#1
    N130G90Z-6.
    =#1
    N140G90Z-8.
    =#1
    N150G90Z-10.
    =#1
    N160G0G90Z50.
    N162M02
    #1
    N112X50.
    N114Y0.
    N116X0.
    N118Y50.
    And last but not least the original Post version
    .N100G70G75G90
    N102G0X0.Y0.T1M6
    N104X0.Y50.
    N106Z50.
    N108Z2.
    N110G1Z-2.F3818
    N112X50.
    N114Y0.
    N116X0.
    N118Y50.
    N120G0Z-4.
    N122X50.
    N124Y0.
    N126X0.
    N128Y50.
    N130G0Z-6.
    N132X50.
    N134Y0.
    N136X0.
    N138Y50.
    N140G0Z-8.
    N142X50.
    N144Y0.
    N146X0.
    N148Y50.
    N150G0Z-10.
    N152X50.
    N154Y0.
    N156X0.
    N158Y50.
    N160G0Z50.
    N162G0Y0.M2
    Oct 2006
    Sub-programs for lathe
    Has anyone used sub-programs to send the machine to it's index position? I want to program a vtl where I can use different subprograms for the index position for different jobs. What is the format like and how does it work?
    Thanks.
