587,462 active members*
3,221 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Help find terminal connector type for this stepper
    Feb 2004
    466
    I got some steppers on a flea market, they where taken from printers.
    This thread discuss them http://www.cnczone.com/forums/showth...ht=japan+servo
    )Japan Servo 85 oz-in 400 Steps/Rev . $29/ea, (- and if you want to see what a quality motor looks like inside, here is the dis-assembled motor, showing the clean design and double stack with ball-bearing construction.)
    Japan Servo TYPE KP56QM2-001, with Ball Bearings on each end of shaft. (note, unless you burn out the windings, and this takes at least a little effort, the only failure mode in step motors is bearing failure - which is easy to remedy as well as rare with Japan ball bearings)
    NEMA23 mounting flange: Motor Length = 75mm from flange to rear of case, Motor Diameter = 57mm. Shaft Length = 14mm, Shaft Diameter = 5.9mm
    6 Wire CT windings 3.5 ohm - 0 - 3.5 ohm,
    Maximum Current: Center tapped - 1.5A , Bipolar, full winding - 1.0A
    note: These motors have been carefully removed from surplus assemblies - leads are 75 mm long, and may require extending for some applications. We guarantee your satisfaction with these motors !! Limited quantity available. $29/ea
    Leads are short, 75mm, and has some sort of connector on them.
    I hope the attachment will help in identifying the connector.
    I wish I could use these connectors.
    Konstantin
    Edit:
    I looked closely at the connector and found tiny print "AMP" on one side and "12" on the other. 6 cables connector.
    Jul 2003
    125
    http://www.mouser.com/amp
    You'll have to dig around a bit to find the right one, though.
    Konstantin,
    Did you ever find the correct mating connectors for your steppers? I have some steppers that look to have the same connector. If not, did you find any 6 lead connectors that you could use to re-wire the steppers?
    Feb 2004
    466
    No, not yet.
    I think its best to cut those off and use other type of connectors.
    I will need extensions anyway and these conn are PCB type, so I guess I wont need a PCB near the motors in the machine.
    Right now I am just hooking it up to my screw clamps directly. Figuring out my electronics.
    Konstantin.
  1. Find Vexta stepper parameter
    By tivoidethuong in forum Stepper Motors / Drives
    Last Post: 04-06-2005, 12:59 AM
  2. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
