Build your own inexpensive DIY swivel drag knife for your CNC mill.
To make your own DIY Swivel Drag Knife Cutter all you need are:
1. one .25" x .125" rare earth magnet from Amazon.com
2. one 5mm OD, 2mm ID bearing from
Boca Bearing Company :: Ceramic Bearing Specialists
3. one 4mm OD, 1.5mm ID bearing from
4. one 3/8" x 12" brass tube from Hobby Town USA or your local hobby store
5. three Carl Goldberg 3/16" wheel collars from Hobby Town USA or local hobby store
6. one spring that slides easily down the 3/8" brass tube, has an ID > .25" and a compression force of 80-150 grams when compressed 3/16"
7. Roland replacement blades 45 or 60 degree from Ebay.com
8. A copper pipe cutter such as a Rigid Model 104.
9. A tiny amount of thin CA (Cyanoacrolate also known as Super Glue)
10. A tiny amount of Loctite 609
11. Digital calipers (very helpful)
To read the complete article go to:
Build Your Tools ? View topic - DIY Stencil Cutting Drag Knife Solution - Update 5!
airnocker
Everything depends on everything else.
