587,449 active members*
2,604 visitors online*
IndustryArena Forum > Maintenance in General > SERVICE FOR CNC-MACHINES > Brother TC-32B wher can I get software files?
Results 1 to 8 of 8
    hello everyone
    I replaced NC PCB, on my Brother TC-32B. I have to upgarade software to newest version, where can I find software files? Should I write to brother service and ask for it?
    Jun 2007
    3891
    Re: Brother TC-32B wher can I get software files?
    call yamezen.
    but that machine is B00 right, meaning its just using a regular pc motherboard? i thought the software was on a flash card?
    Quote Originally Posted by ihavenofish View Post
    call yamezen.
    You're right is B00. Look at the alarm appear after NC PCB replacement.
    0096 **Version error
    Alarm cause: the combination of main/slave/local versions is not correct because NC board has been replaced.
    Recovery method:
    1. Revert to the original part
    2. Upgrade software.
    Jun 2007
    3891
    ah.
    did you not buy the exact same board? or did you try to use just any old pc board?
    i expect the original board has custom firmware that needs to be present.
    ah.
    I bought new one. It's exactly the same board but it's newer version. I had to replace it cuz I had alarm "Check sum error(macro variables)."
    Jun 2007
    3891
    ah ok.
    call yamazen then. i guess there needs to be some form of software update.
    ah ok.
    Thanks for your help.
    Nov 2019
    21
    Quote Originally Posted by damian7057 View Post
    to upgarade software to newest snaptube telegram web version, where can I find software files? Should I write to brother service and ask for it?
  1. brother (conversation) mode Editor or software
    By Razahan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-26-2022, 10:22 PM
  2. milltronics parner 3 y output wire wher does it go
    By dustang in forum Milltronics
    Last Post: 12-19-2008, 01:25 AM
  3. Brother HS-70a wire EDM Tech files?
    By RHoffer in forum EDM Discussion General Topics
    Last Post: 10-31-2008, 10:54 PM
