587,818 active members*
3,244 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > which cnc package cuts 2D parts with least extraneous cuts?
    Oct 2006
    14
    Heya guys,
    which CNC package cuts 2D pockets the most intelligently, with the least amount of running over paths that were already cut, and with the least Z repositioning moves (for 2 axis cutting)?
    Oct 2004
    742
    Quote Originally Posted by mbwittig View Post
    Heya guys,
    I don't know if it is possible for anyone to answer your question due to the following:
    Are you referring to a design CAD / CAM package, or to a program like Mach3 which sends out step / direction signals to move the various axis?
    The actual paths to cut the pockets is the g-code which is created either manually, or by a program which creates the g-code from a CAD drawing.
    If the part with the pockets is created via a CAD package, the g-code produced will be in the order that the part is drawn. (First cad line = first cut). However, some CAD / CAM packages that can also produce the g-code files, may have built in algorithms to maximize the g-code and therefore minimize the machine cutting time.
    Sorry I cannot give you an answer to your question.
    Oct 2006
    14
    True, I should have said CAM software. Mastercam, Surfcam, etc... OK how about some opinions now.
    Jul 2005
    2415
    Try SheetCAM. All CAM programs tend to have some overcut problems even the real expensive ones. The pocketing cut (spiral cut) has worked good for me in the past. The price differential may convience you to give it a hard look.
    www.sheetcam.com
  1. My new TM-1 cuts!!!!!!!!!!!!!
    By blackhollowmfg in forum Waterjet General Topics
    Last Post: 03-16-2007, 02:24 PM
  2. More first cuts
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 11-27-2006, 05:00 PM
  3. More first cuts
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2006, 02:19 PM
  4. First cuts
    Last Post: 10-27-2006, 05:17 PM
  5. First cuts
    By no priors in forum MetalWork Discussion
    Last Post: 08-21-2006, 04:03 PM
